Okay, so the other day I decide to go ahead and finally upgrade my Mac Pro, the CPUs arrived today and I successfully delidded them (by successfully I mean nothing appears broken!)
Now, here's the kicker, I install the new CPUs in, and I hear the chime, but nothing comes up on the display.
I've remounted the CPUs three times, each time it chimes.
I go back and reinstall the original CPUs, exactly the same issue.
Now, I upgraded my GPU a year or two back and foolishly sold the GT 120 that came with it, so I have no EFI card, and therefore can't see the boot screen.
The HD 7850 that I replaced it with has been acting strange for a while, I'm fairly sure the fan is on it's way out as it only comes on at max speed for a few seconds, then cuts out. Recently, I've been having black lines randomly across both monitors so I guess it's dying.
So, my question are...
Has the GPU finally died at the most inconvenient time?
Would it chime if the CPU didn't survive the delidding
When you change a CPU on a Mac Pro 4,1 (upgraded to 5,1), do you need an EFI card. I have no issue buying another GT 120 if i need, I sold mine for more than they're on ebay for so I'd still be in a profit, just mildly inconvenienced.
Laptop:
HP OMEN 15 - Intel Core i7 9750H, 16GB DDR4, 512GB NVMe SSD, Nvidia RTX 2060, 15.6" 1080p 144Hz IPS display
PC:
Vacancy - Looking for applicants, please send CV
Mac:
2009 Mac Pro 8 Core - 2 x Xeon E5520, 16GB DDR3 1333 ECC, 120GB SATA SSD, AMD Radeon 7850. Soon to be upgraded to 2 x 6 Core Xeons
Phones:
LG G6 - Platinum (The best colour of any phone, period)
LG G7 - Moroccan Blue
https://linustechtips.com/topic/1234887-mac-pro-cpu-upgrade-issues/
1 minute ago, BlueScope819 said:
GPU has some problems, get it replaced ASAP. As for the CPU if it chimes the board isn't broken, probably an OS problem. Can you boot to a linux USB while holding down the option key to select it?
Issue is I don't have an EFI card so even if it worked, I couldn't select a boot option!
Could certainly be an OS problem, I don't have another Mac so I'm currently setting up a VM on my laptop to check the drive
Laptop:
PC:
Mac:
Phones:
