Modify memory manually vs setting docp and modifying it
Solved by nick name,
1 minute ago, lotus10101 said:Interesting, so this droop in bclk while in a docp profile could explain why I can use 1T but when I'm not in docp and set the exact same timings same voltage I cannot and it will crash at startup unless I put voltage I'm not real comfortable with lol
Hmmmm. A small drop in BCLK wouldn't explain that, but maybe Spread Spectrum would?
What mobo do you have?
