Need HELP ASAP
Solved by Mateyyy,
1 hour ago, Riderz said:
I'm going to assume the 101C reading is a false reading, though check (also in HWiNFO) that PROCHOT and "Thermal Throttling" appear as "No".
Have you made any notable changes hardware or software wise right before this started happening?
Try setting your power plan in Windows to High Performance.
Try going into the BIOS and disabling SpeedStep (or it might be called EIST on some BIOSes).
