Need help planning a build :)
Go to solution Solved by FavoringWinter,
1 hour ago, Themaindude202 said:
Thanks for the help. i also have sorted thru newegg and found this for 823. any thoughts? https://newegg.io/5dace81
I think that if you do the build that I did for now, than upgrade to rgb ram/case fans it would be best. Also you do not need to buy windows. Create a usb installation drive, than buy a key for 10 dollars online.  for 850 rgb would be a low priority if you want 32gb ram, and good performance and products. and the psu would have the fan facing down so you would not be able to see it anyway. you can always swap out cpu coolers over time as well
Budget (including currency): 850 USD
Country: United States
Games, programs or workloads that it will be used for: Modern Games and Video Editing
Other details: please just find the best parts for this price and not like cheapest but highest rating and overall quality. i’ve upgraded a few pcs but this will be my first build. please give me a list of parts you know will work together. thank you for the help :)
https://linustechtips.com/topic/1234482-need-help-planning-a-build/
37 minutes ago, Themaindude202 said:
only parts i am “requiring” are an ssd and find parts that have rgb.. i like it. the case should have a viewing window ofc. at this point in time i will be running one monitor and i have peripherals already.
for 850 prioritize performance over looks, ssd is fine, but rgb should not be a must. You will have a much better time.
    Forgot to put, add some case fans as well
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Walmart)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($99.99 @ Newegg)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($53.99 @ Newegg)
Storage: Silicon Power A60 512 GB M.2-2280 NVME Solid State Drive  ($54.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: XFX Radeon RX 5600 XT 6 GB THICC II Pro Video Card  ($269.99 @ Amazon)
Case: Cougar MX330-G ATX Mid Tower Case  ($51.98 @ B&H)
Power Supply: be quiet! Pure Power 11 500 W 80+ Gold Certified ATX Power Supply  ($69.90 @ B&H)
Total: $830.82
Generated by PCPartPicker 2020-08-14 22:40 EDT-0400
