Games freezing for a few seconds every few minutes.
BikerMat
As the title says, a few of my games keep freezing for around 10-20 seconds every few minutes. So far it's only happening on Smite and in PvP on WoW and it's only started happening in the last couple months.
My ISP, Kingston Communications is a rather terrible one, our internet cuts out/in constantly during the day and is never up for more than an hour at a time past 8pm :(, sadly though my parents refuse to actually do something about this. So is what's happening, happening because of KC, or would there be something I could do on my end? Router is fine, it's been replaced several times in the last few years because of these cut out/in's and I use a usb wireless dongle to connect to it.
Does this happen when you are playing any offline games?  Can you be sure that it is your internet connection that is causing the problem?
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
It only happens online, and it feels as if I'm desynced with the server/game, for example in WoW I'd try to cast an ability or get on a mount and nothing would happen, my character would just be stood there until a few seconds later when presumably my client catches up and I start casting. Outside of PvP though I've not had this issue once other than Smite.
