i just bought a hyper rgb black edition.
i connected its rgb connector dirctly into the mobo.
its just showing a yellow colour.i don't know how to change color.
i installed gigabyte rgb fusion 2.0.its only showing the rams and i can cycle the colors of rams.
but the cooler is not showing there.
https://linustechtips.com/topic/1233899-need-help/
The software has no way of knowing what CPU cooler is connected.  You have to control it through the motherboard RGB software, so if it's a gigabyte motherboard, RGB fusion should have a section dedicated to the motherboard itself.  You will have to play around and see which header is which and you can configure the color there.
System 1:  AMD Ryzen 9 5900X | MSI X570 MEG UNIFY | 32GB Crucial Ballistix DDR4-3600 | Nvidia RTX 3090 FE | custom loop (3x 360mm rads, Optimus Foundation AMD CPU Block, Bitspower BP-VG3090FE, Aquacompter D5 NEXT, Radikult O11D-XL UNO) | Seasonic GX-1000 | Lian-Li PC-011 Dynamic XL (black & silver) | Windows 10 Pro x64 | 512GB Toshiba RD400 NVMe (OS) | 2x 1TB Sabrent Rocket NVMe in RAID 0 | 6.4TB ioMemory PCI-E storage | 55" LG C9 OLED
System 2:  AMD Ryzen Threadripper 2920X | MSI X399 Gaming Pro Carbon AC | 32GB G.SKILL Ripjaws V Series DDR4-3000 | AMD 5700 (flashed with 5700XT bios) | custom loop (1x 280mm rad, 1 x 120mm rad, Optimus Absolute Threadripper 3+, Heatkiller IV for reference 5700, Aquacompter D5 NEXT, Alphacool dual-bay res w/ D5 mount) | Seasonic GX-850 | Silverstone FT-02 (red/black) | Windows 10 Pro x64 | 512GB Toshiba RD400 NVMe (OS) | 2x Seagate 4TB SSHD in RAID 1 via LSI 9265-8i | 55" LG C9 OLED
Laptop:  Dell XPS 2-in-1 | 15.6" 4K Ultra HD Touch-Screen | Intel Core i7-8705G | 16GB Memory | AMD Radeon RX Vega M | 256GB SSD | Windows 10 Pro x64
https://linustechtips.com/topic/1233899-need-help/#findComment-13918429
the rgb software doesn't control anything to do with the CPU fan except the color.  It isn't a data connection like USB, it's an analog connection like a fan header.
https://linustechtips.com/topic/1233899-need-help/#findComment-13922176
On 8/13/2020 at 4:58 PM, alihaider741 said:
@cawilkey
my cpu fan is also not detected.and that's why no software is detecting the rgb fan
Those two use different cables. Your PC wouldn't boot if CPU fan would not be detected correctly. Besides, its spinning so it works.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1233899-need-help/#findComment-13923269
