i have gotten this old p223w acer monitor today, and im sorry in advance my english seem to be rusty. i quiet enjoy this new monitor <3, so if someone is able to answer my question you are my hero <3 :D.
and the question im going to ask is.
Are there any difference with the cursor/sensitivity moment between these 2 with Black bars?
(adjust screen conditions) Button selected, had to change horizontal from 100 to 0 to get same blackbars from preserve screen scaling.
or
(preserve screen scaling) top selected, Black bars doesnt work with higher refresh than 60hz.
but is the mouse/senstivity moment any different if i manual scale it to 0 to get black bars or is the sensitivity the same?.
//Tobias <3 hope someone can help me with this
https://linustechtips.com/topic/1233865-intel-hd-43streched-issue-help/
i don't belive the mouse sensetivity has any affect with the setting you make in the intel graphics controlpanel.
(hvorfor har du også skaleret den til 1680 x 1050 i stedet for 1920x1080?)
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
Im using black bars when i play some counter strike global offensive.
was just wondering if the sensitivity have changed when i scaled the horizontal from 100 to 0 :D <3.
i use 640x480 ingame 75hz, intel hd4600
current monitor dont support higher than 1680 x 1050 :D
remember to quote or @flashiling otherwise i can't see that you responded :)
you sure it supports 75Hz?
in the windows settings it's possible on some monitors to enable 75Hz even though it's a 60Hz monitor which just causes slight studdering and for the screen to act weird.
but no it shouldn't have any effect on the mouse sensetivity
@flashiling thank you so much Flashiling :D❤️ yo made my day,
it is just an old monitor which runs between 60-82hertz refresh rate, and no issues.
only that i had a 4:3 black bars scaling issue so thank you again so much for your time and for asnwering :D❤️ have a great day vh Tobias :D❤️
