what temps do you get
Is it on stock or overclocked? Also, how much load is it on?
CPU: Ryzen 7-3700x 4.4GHz, MB: ASUS PRIME B450M-AGPU: SAPPHIRE RX 590, RAM: 16GB Corsair 3200MHz, SSD: 480GB Kingston HDD: 2TB WD Green, CHASSIS: CoolerMaster HAF 912, PSU: CoolerMaster Thunder 700W, COOLERHyper 212 Black Edition
https://linustechtips.com/topic/12335-1055t-cpu-temps/#findComment-131639
36 c and 46 c in idle
and i dont no my loads
and its is not overclock
its stock
mid tower case
AMD 1055T 2.80GHZ WATER COOLING TURBO ON NOT OVERCLOCKED
WINDOWS 7  64 BIT
1 TB
5770 1gb
GIGABYTE GA-770T-USB3
KINGSTON HYPERX from 8gb to upgrading to 16gb
700 WATT
with 2 displays 1440/900
https://linustechtips.com/topic/12335-1055t-cpu-temps/#findComment-131656
