GTX 1660 temps
By
SavvySovage
in Graphics Cards
in Graphics Cards
Solved by Skipple,
83 seems perfectly normal to me as long as your boost speeds aren't dropping. If you want, and don't mind the noise, you can play with your fan curves in afterburner to reduce those temps a bit.
1
toxic_worper ·
6
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning6
