GPU temperature and airflow
Solved by boggy77,
1 minute ago, TheNiceGuy66 said:so is it fine for me to game with the side panel off for as long as i want?
if that solves your problem, then yes. but it shows that it's a very bad case you have.
Vibora ·
Posted in New Builds and Planning3 -
4
3
Doctah ·
Posted in Peripherals1 -
5
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards3 -
Packhunter ·
Posted in Graphics Cards5
