Just got my new case
Took the 2 front fans off and i noticed that the screw doesnt go easy from the other side of the hole
Should i just force them in and crate the grooves?
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
https://linustechtips.com/topic/1232434-case-fans/
Yeah just force it in. From my experience, case fans don't come with pre-made grooves. You make the grooves yourself when you put in the screw for the first time.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
https://linustechtips.com/topic/1232434-case-fans/#findComment-13906087
They're self-tapping screws, which means they actually bite into the plastic when they screw in. The side you're screwing into hasn't had threads made by the screws yet, so it will be tough to turn at first. Once you get the screw through the plastic, it will become much easier to turn.
https://linustechtips.com/topic/1232434-case-fans/#findComment-13906094
