Hey can anyone help me out I recently bought a cougar vortex fcb 120 cooling kit about a month ago. I recently swapped out the power supply and now all 3 fans are halfway lit up and the LEDs that do light up don't even change colors anymore. The fans were definitely working fine right after I swapped the power supply. But if the LEDs are dead in some areas shouldn't the switch change the colors of the ones that work.  I attached an image of one of the fans .
https://linustechtips.com/topic/1232357-rgb-fan-help/
Re-connect everything, test them one-by-one, try every button on controller. And if everything fails, RMA.
Hard to really provide any more help as I can't see any documentation of product page.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1232357-rgb-fan-help/#findComment-13912477
