I cleaned my GPU and my audio stopped working.
Dragon_Warden
So earlier today I cleaned my GPU after I put it back in my audio stopped working. Everything is detected but no audio comes out of my headset.
Thank you in advance.
select your motherboard souncard as the primary audio output, not the gpu hdmi.
The previous tip should work fine. If not, take the computer to a professional service.
1) click here:
2) then here:
3) search "sound output" and select "Choose your sound output device":
4) select the correct output for your speakers / headphones from the list:
That should get your sound up and working again. Keep us updated :)
AMD RYZEN 7 5800X3D \ Gigabyte X570 Aorus Elite \  32GB 3600 G.SKILL Neo \  Gigabyte RTX 4080 Gaming OC \  Lian Li O11 Dynamic Evo \  NVMe 2TB Samsung 990 Pro, SATA 4TB Samsung 970 Evo  \  WINDOWS 11 PRO
It never troubles the wolf how many the sheep may be. ~Publius Vergilius Maro circa 50BC
I've gone through the bios to make sure I have my motherboard'sound card active. But it still doesn't work, and I've set my headset to the default output. The headset does work with other devices.
If it helps my specs are
Ryzen 3200g
Gtx 750ti
16gb ram
B450 d3sh
I made It in April.
Do you think an external sound card could solve it.
Yes, you can get an external audio.
The internal might be broken. Since it is still warrantied, why not claim it.
My pc says I should be getting audio but I am not able to hear it through any headset or speaker.
