So it's basically what the tittle says, every time I install CAM on my desktop it works until a reboot or shutdown. The next time I boot the system It freezes and I start having GPU problems.
The first time I had this issues was with an old HD5850. Now I'm having this issue with an R9 270X.
Both times I had to reflash the cards BIOS or it would not ramp up its clock or cause the GPU to not let the PC boot. Even tried removing the GPU and setting it in my friends system with the same result.
The reflash was the only solution. Why am I worried if its fixed now you may ask. Well I recently saw a PC mod that you put an old cellphone in the PC so you could use it as a second screen to monitor temps and stuff.
Thought it was nice since I could remove it if I wanted and since I do have an old fone just chilling in the closet.
I wanted to know if there is a way to fix this or if there is a software thats "nice" looking just like CAM. Would like to have GPU,CPU, MEM and HDD info in one place. Customization is a factor that interest me on CAM.
Any help?
Current system
AMD based:
CPU: FX 8320E
GPU: R9 270X black edition
Memory: 10GB DDR3 1600mhz
Storage: 480WD SSD
MB: Asus M5A78L-M
PSU: EVGA 600B non modular
Case:Cooler Master H500P Mesh
CPU cooler: Cooler Master MA610P
Its a pretty old system that I will be switching for a new one by the end of the year.
https://linustechtips.com/topic/1232055-nzxt-cam-causing-gpu-bios-problems/
