I bought 2x8GB RAM 3200MHz but I checked at what speed it is at currently and it says 1332 MHz, how do I change it to 3200MHz (do I do it in the boot menu and if yes how do I do that), is it safe to run at that speed if it says it can and what are the pros/cons of running at a higher speed like at 3200 MHz instead. I have a MSI B450 GAMING PRO CARBON AC Motherboard
https://linustechtips.com/topic/1231815-ram-speed/
Depends on where you are looking but you are prob running at 2666 (1333x2) by default. You need to adjust XMP settings in BIOS.
ask me about my homelab
https://linustechtips.com/topic/1231815-ram-speed/#findComment-13901317
Yes
Higher mem clock = computer go faster.
Lower mem clock = computer go slower.
https://linustechtips.com/topic/1231815-ram-speed/#findComment-13901327
If it says 1333Mhz, that's really 2666Mhz. DDR is double data rate, so you, well, double it. That, then, is your base clock on your RAM. 3200Mhz is technically an OC. To achieve that, you need to enable it's eXtreme Memory Profile, or XMP, in the BIOS. It's also sometimes referred to as DOCP, if you see that instead. This is quite literally a profile of clock speed, voltages and timings, that the RAM can safely and reliably OC to.
Like any OC, there is inherent risk, and Intel, in particular, voids your CPU warranty if you actually enable XMP. However, practically, no one ever damaged their RAM or CPU simply enabling XMP. It's about as safe as safe can get.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1231815-ram-speed/#findComment-13901358
