I'm having a tough time trying to figure out how to create a macro for use with Photoshop with LUAmacros. I already have most of them set up for use since they're just simple combinations that we're made pretty easy to do with the cool video below. But now I'm trying to make a macro that registers a continuous press (for space and shift for Photoshop) since I'm mapping it all to a num pad. I have very, very little coding knowledge and don't really know what to do.56180857_Ashampoo_Snap_WednesdayAugust52020_20h36m37s_001_.png.e30e815838fc6faae8ef56242bfc5f95.png
Just here for some fun.
PC Build 1: Great Ape (Main Rig) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/nKjHGX
CPU: Ryzen 3700X
GPU: ASUS GTX 1070Ti 8GB ROG STRIX
PSU: SeaSonic FOCUS Plus Platinum 750 W
Mobo: MSI MPG B550 GAMING CARBON WIFI
Case: Corsair 4000D
PC Build 2: Piccolo (Emulation/ITX/Transportable) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/tDBdHx
CPU: Intel i5-11400
GPU: EVGA GTX 1060 3GB SC
PSU: EVGA SuperNOVA GM 550 W
Mobo: ASRock Z590M-ITX/ax
Case: Silverstone RVZ03
♪♫ "2-to the-1-to the-1-to the-3 I like good OC and RGB. Configure so much, you wouldn't believe. And I get more blue screen than a Walmart PC" ♪♫
https://linustechtips.com/topic/1231026-lua-macros-help/
