Help! Computer not booting!
Solved by BlackManINC,
45 minutes ago, Louie Friesen said:I can try replacing the PSU (I'd do that first), because for a hackintosh, the mobo is quite specific.
I think I'll get one of these:
Seasonic FOCUS GX-850
Seasonic FOCUS PX-850
Asus ROG Strix 850G (the OEM is Seasonic)
I can always return the PSU if I have the same problem.
Yeah, either one of the Seasonic ones would be a good pick. I would steer clear of the Asus one only because its missing the Under Voltage Protection feature.
