delid that man :D only way to fix it
CPU 5900x| GPU 3080ti FE| MOBO MSI MPG CARBON MAX| RAM 32GB VENGENCE PRO 3200Mhz| STORAGE Samsung 980 Pro 1TB,2X WDSN750,4TB Seagate Barracuda| COOLING 1x Corsair 360mm XR7 54mm Radiator,1x EK-CoolStream PE 360mm Radiator| GPU Block: Corsair Hydro X Series, XG7 RGB| CPU Block: Corsair Hydro X Series, XC5 RGB| Fittings: EK-Torque STC & Corsair Hydro X Series XF| Pump/Res: EK-Quantum Kinetic TBE 300 D5| Tubing: Corsair Hydro X Series XT Softline| Liquid: Corsair Hydro X Series XL5 Clear| Fans: 10x Corsair SP120 RGB
https://linustechtips.com/topic/122995-cpu-temps/#findComment-1636554
You could have a bad mount, I would reset the cooler. I get a peak of 57 degrees C on my 3570k and a h110 while running prime95. Are your fans running at full speed?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/122995-cpu-temps/#findComment-1636579
i dont think so, it's quiet! :)
then se corsair link to speed them up
https://linustechtips.com/topic/122995-cpu-temps/#findComment-1636759
no just the fact that the 10c difference in-between the cores when same load and voltage
It's either a bad mount (Still shouldn't cause a big variation between cores, which is odd) or your CPU has a particularly badly applied thermal paste under the IHS. If you have the balls and the money to replace it, take a razor blade to that IHS. I know I will be with my 3770K to lower temperatures.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/122995-cpu-temps/#findComment-1637055
