I recently upgraded my PC to have a few new parts with a emphasis on ARGB. After I finished the build, it worked fine for a few days, but all of the sudden the RGB is acting strange.
On all RGB components, only one led is lit up. So only a small section of the fan, my case and a RGB strip are lit up. The RGB RAM on my mobo is functioning just fine. All the other components are attached to the only 5V3pin connector on my motherboard through the built in splitters on the cables of the parts.
I've fiddled with the connections and have assured they are solid, uninstalled and reinstalled AURA, and have tried other RGB softwares to no avail. I am stumped because it did work fine for a few days and now it wont work at all. Below are pictures of what the issue looks like.
PC Specs
Asus Prime X570-P AM4
AMD Ryzen 7 3700X
G.SKILL TridentZ RGB Series 32GB (2x16) (Workiing RGB)
Cougar Gemini S Case (Malfunctioning RGB)
MSI Geforce 2070
Enermax Liqmax III Addressable RGB CPU Cooler (Malfunctioning RGB)
Corsair RMx 850W ATX 12V PSU
Dreamcolor Magnetic Addressable LED Strip Light (Malfunctioning RGB)
https://linustechtips.com/topic/1229532-problem-with-rgb-setup/
