Hey-
I'm looking at Sub-$100 true wireless earbuds for working out, and want to ask the forums for some options. As I mentioned, I'm looking to use these primarily for exercise, but I won't be used for exercise exclusively. High priorities for the earbuds are a comfortable fit, decent battery life, Bluetooth connection strength, and of course some type of water/dust resistance if possible. Currently Sound quality is a nice-to-have, and I'm not in the market for earbuds that try to imitate audiophile/sound neutral headphones. I don't plan on listening to particularly quiet or detailed music, but I will at... eh fairly high volumes. Right now I've been looking at the Jlab audio JBuds, if you've heard of them. One of my concerns about it is that I use an Android phone, and these headphones only support AAC which isn't supposed to play very nice with Android. How would that compare to headphones with aptX support?
Ty for reading my rant, any and all advice is gratefully accepted, just please let me know if you're not very experienced with the topic, or are unsure of your recommendation.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1228733-true-wireless-earbuds/
KZ S1/2, I use the S1 daily for everything from gym to just going for walks, they released the S2 the day after I ordered the S1 and I haven't had a chance to check them out but I've heard great things.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1228733-true-wireless-earbuds/#findComment-13877867
Cambridge Audio Melomania 1 might be in budget.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
https://linustechtips.com/topic/1228733-true-wireless-earbuds/#findComment-13880202
