Budget (including currency): about 1000
Country: us
Games, programs or workloads that it will be used for: r6, photoshop,csgo, etc
Other details: Im mainly looking to seek supervision for my build. Im using pc part picker and want to know if my build is alright. I already have a power supply fans and a case. The parts i have are. A Ryzen 5 3600
A Gygabyte x570 aorus elite motherboard.
Some 2x16 ddr4 3600 ripjaw ram
And a radeon RX 5500 XT 8gb graphics card.I already have a hardrive. Will this build be good for gaming and potentially photoshop?
https://linustechtips.com/topic/1228712-my-first-build-help/
Country: us
it does not bad imo. check if the mobo has onboard wifi unless ur using ethernet, what CL is the ram? also it might be better to 4x8 i think.
5500xt is ok, but maybe you could get a 5600?
even with a 5600xt its still much lower than 1000?
ev
stuff is cool. stuff that has fancy lighting is cooler. stuff that has fancy lighting and works is the coolest.
i game so i know a bit abt gaming tech, not much abt professional tech.
writing this as i finish a 3 hour D2 sesh so excuse anything wrong.
https://linustechtips.com/topic/1228712-my-first-build-help/#findComment-13875225
I made this list which is much better than yours
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($279.99 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($124.99 @ Best Buy)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($119.99 @ Newegg)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($89.95 @ Amazon)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE 2X Video Card  ($399.99 @ Newegg)
Total: $1014.91
Generated by PCPartPicker 2020-07-30 21:58 EDT-0400
You might want to swap the 3700X for a 3600 and spend more on your GPU if you want better gaming performance at the expense of photoshop.
https://linustechtips.com/topic/1228712-my-first-build-help/#findComment-13875231
Memory: Team T-FORCE VULCAN Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($102.99 @ Amazon)
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive  ($69.98 @ Amazon)
Video Card: MSI Radeon RX 5600 XT 6 GB MECH OC Video Card  ($269.97 @ B&H)
Case: Cougar MX330-X ATX Mid Tower Case  ($43.99 @ Amazon)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $991.90
Generated by PCPartPicker 2020-07-30 21:52 EDT-0400
If you want more gaming performance at the cost of photoshop you can swap the 3700X for a 3600 and go upto a 2060.
You can also get a aftermarket cooler if you have some extra money
And you can use your old harddrive for mass storeage and fast things on the SSD
And the case is mostly personal preference.
hes got a PSU + case, so i think you can use a x570 instead of a b450
https://linustechtips.com/topic/1228712-my-first-build-help/#findComment-13875239
ev
I should have expressed this or lowered the budget but this budget of 1000 is including the case and hardrive. My motherboard does have a wifi chip . My ram is cl18
https://linustechtips.com/topic/1228712-my-first-build-help/#findComment-13875244
No. Always two sticks if you're running dual channel. 4x8 just makes half your RAM slower to access than it needs to be.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1228712-my-first-build-help/#findComment-13875249
1 minute ago, Darpyface said:
I noticed, updated the build. No reason to go X570 really, he's not going to use PCIe Gen 4 and the Tomahawk Max is good enough.
yeah true
https://linustechtips.com/topic/1228712-my-first-build-help/#findComment-13875252
