So I'm currently looking for a gaming mouse (Budget is 50 USD but can go above if makes sense to). I need a mouse that has side buttons, not too many though. My current mouse has 2 buttons but I was looking for a mouse with preferably 4 buttons. More is okay as long as it's not tight. As I don't want buttons that are too close like this (figure 1)
figure 1: https://imgur.com/a/5dVdFwj
Can anyone please recommend something? I personally don't care about the weight, sensitivity or anything like that. I just care about the buttons and a medium-big sized mouse as my hands are big (The bigger the mouse the better).
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/
If all you care about is buttons, maybe the G402/502 or the Razer Basilisk. They all have 3 side buttons. I don't think you can have a mouse with more than that unless you want an MMO mouse with a ton of closely positioned buttons.
The Razer Naga might also be worth checking out.
-Moved to peripherals-
EDIT: Just to clarify, you want a mouse that has more than 2 total buttons or side buttons?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13870712
I would suggest looking into the Logitech M510/M570 or the G402/G502:
https://www.logitech.com/en-us/product/wireless-mouse-m510
https://www.logitech.com/en-us/product/wireless-trackball-m570
https://www.logitechg.com/en-us/products/gaming-mice/g502-hero-gaming-mouse.html
https://www.target.com/p/logitech-g402-hyperion-fury-fps-gaming-mouse/-/A-53859021
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13870775
more than 2 Side  buttons
Also, both mouses look good but are a little pricey.
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13871008
wait, where are you buying from? i dont recall any of the mouse that @PCGuy_5960 mentioned that are above $50, unless you are looking at the basilisk ultimate and g502 lightspeed.
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13871033
Didn't go to a specific store, just went into googled and typed that in and it said 60 something euros
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13871096
are there any sites we can search from?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13871102
Newegg? or real any trustworthy site that has free delivery
are you buying from the US?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13871110
If you mean where the item is shipped from then I don't know
if you mean where I live then no, I live in Oman
then, do you have any websites for purchasing mice in oman? this was what i ask before if i was unclear.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13871128
I've checked, they have limited products and couldn't find anything to my liking.
i see, are they not in stock or are they not available at all? unfortunately, its pretty hard to recommend if we dont know whats available.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13871152
Have you looked for the G402? You can usually find it for less than $40
https://linustechtips.com/topic/1228171-help-choosing-a-mouse/#findComment-13871164
