Hi!
I have an issue that I'm not able to figure out how to solve.
When I cold start my computer everything is normal, even if I reboot the computer shortly after a cold start it's fine.
But if I've used it for a while and then reboot I get no post, nothing happens; monitors are black and neither mouse or keyboard is turned on.
I don't know if this is related, but sometimes when I play a game my monitors go black and after a couple of seconds the computer reboots (I think) into the same issue.
I cannot find the solution in any forum, the closest one is this:
Even if I haven't seen any other issues regarding faulty CMOS battery, after reading this post I put in a new one.
At first I thought this fixed the issue since the computer seemed to be working correctly, but after approx 1 week I noticed that the same issue was still there.
Both the old and the new batteries are CR2032 3volt Lithium, but not the same brand.
Is it possible that a new CMOS battery will fix my issues and that the one I put in is somehow not compatible?
If the CMOS battery is not the solution, please help me find what it is, any inputs are appreciated!
Specs:
MOBO: Asus TUF B450m-PLUS Gaming with BIOS version 2202 (latest)
OS: Win 10 64
PSU: Corsair RM850x
GPU: ASUS GeForce GTX 970 STRIX 4GB DirectCU II OC
CPU: Ryzen 7 3700X (Asus optimal setting in BIOS otherwise NOT OC)
RAM: Corsair Vengeance LPX Black 16GB (2x8) 3200 MHz CL16 (DOCP enabled to get 3200MHz)
COOLER: Noctua NH-U12S chromax.black
DRIVE: Samsung 970 evo plus M.2 500GB
CASE: Fractal Design Node 804
Temps when manual reboot: CPU: 55-60, GPU: approx 60 (Celsius)
Temps when gaming: Both CPU and GPU approx 70 (Celsius)
https://linustechtips.com/topic/1227064-no-post-after-reboot/
I'd turn off the ASUS Optimal setting. Reset the BIOS to factory defaults, re-enable XMP, and then try that for a while. If you still have issues, it could be a faulty power supply.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1227064-no-post-after-reboot/#findComment-13861737
Thanks for the tip, but wont that remove the B450's support for Ryzen 3000? (I had to update BIOS before putting this cpu in, was running a 2400G before)
Just out of interest, what make you believe it is the PSU that is faulty? Any particular reason?
I also want to add that I got the same problem when I after 4 hours of gaming without any issues shutdown the computer and turned it back on manually after about 15 seconds.
https://linustechtips.com/topic/1227064-no-post-after-reboot/#findComment-13862307
