Posted July 26, 2020 MSI GS65 laptop (i7-8750H and GTX 1060) I recently re-pasted the CPU/GPU cooling fan assembly (it's a single assembly of 3 fans connected by heat pipes). It was successful and thermal throttling of the CPU has been mitigated. Running Prime95/CinebenchR20 it hits max 88C. However, it appears I did not do such a good job on the GPU because it is now hitting 91C running Heaven whereas previously it maxed out around 85C. HWiNFO64 does not indicate GPU thermal throttling but 91C makes this laptop sound like a Boeing 747. Should I let it be? Should I re-repaste? Link to comment https://linustechtips.com/topic/1226851-poll-re-repaste-or-not/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 27, 2020 22 hours ago, shahaan said: However, it appears I did not do such a good job on the GPU because it is now hitting 91C running Heaven whereas previously it maxed out around 85C. Your GPU run slower because your CPU might be throttling. Now your CPU is not throttling, I think your GPU is capable to reach its full potential. As long as the GPU can be cool off if it is idling, the system looks fine. 22 hours ago, shahaan said: HWiNFO64 does not indicate GPU thermal throttling but 91C makes this laptop sound like a Boeing 747. That's normal for a gaming laptop. Your laptop is trying its best to get rid of the extra heat the GPU generated. Anyway, did you clean the fins? Try taking out your fans and clean the fins. It might help reduce the temperature. I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible. Link to comment https://linustechtips.com/topic/1226851-poll-re-repaste-or-not/#findComment-13862803 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 27, 2020 also what TIM do you use? 3% improvement show you don't need to reapply Link to comment https://linustechtips.com/topic/1226851-poll-re-repaste-or-not/#findComment-13862814 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 27, 2020 Author Okay. Thanks for the votes! I re-pasted. First off, I saw the MX-4 paste I had used the first time had spread well over the CPU but did not spread fully over the GPU. Almost half the GPU did not have any thermal paste on it, so that accounts for the straight up 91C the GPU was hitting within a few minutes of starting Unigine Heaven 4 benchmark. So for the re-pasted I decided to try out a TIM called IC Graphite Thermal Pad. It's not a paste, but comes in a 30x30mm or 40x40mm piece which needs to be cut to the size of the CPU/GPU. The benefit is that it can be cut to exactly the size required so I can be sure the full area is covered. Here are the results: CPU max 88C while running CinebenchR20/Prime95 with no thermal throttling. Same as before. GPU down from 91C to 84C while running Unigine Heaven 4 benchmark with no thermal throttling. Success! Again, thanks everyone for your suggestions and votes. Link to comment https://linustechtips.com/topic/1226851-poll-re-repaste-or-not/#findComment-13864642 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 27, 2020 Author Oh, I forgot to mention... Before re-paste Unigine Heaven 4 score = 1592 After re-paste Unigine Heaven 4 score = 1644 Link to comment https://linustechtips.com/topic/1226851-poll-re-repaste-or-not/#findComment-13864667 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
