So I opened up my old hand-me-down PC Thinking of upgrading the GPU and found this Sketch AF PSU In the case, under the name 'Sun Pro ATX-550w' I have never heard of the brand.
My 2 questions are:
1. Should I swap it out with a more well known PSU or continue to push my luck
2. If I was to keep the PSU should I go through with my upgrade of the GPU
(Specs-  i7 2600 - AMD hd 6450 1gb - 12 gbs of DDR3 RAM - 60 gb SSD - 1TB Seagate HDD)
https://linustechtips.com/topic/1226795-sun-pro-psu/
My 2 questions are:
I've never heard of it, it's probably safer just to get a new PSU if possible, even if it's fine it probably is not very power efficient at all.
Laptop: HP Spectre x360 13t, i7 8565u with 16 gigs, 512 gig  nvme ssd, UHD 620 4k
Other laptop: Acer Chromebook cb3 431 with 4 gigs, celeron n3060 with hd 400 and 16 gigs eMMC soon to be a minecraft server?
Remeber to tag people or else they wont see your post.
https://linustechtips.com/topic/1226795-sun-pro-psu/#findComment-13859704
Wow, that's an old piece of junk.
8 minutes ago, Faceless_ said:
My 2 questions are:
Aren't they the same questions? Well the answer is the same regardless...
You should definitely replace it.
https://linustechtips.com/topic/1226795-sun-pro-psu/#findComment-13859715
