Plugging directly into back of motherboard.
Not working, installed drivers and nothing.  Motherboard is MSI P67A-GD53 B3
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/122598-usb-3-not-working/
I'd uninstall the current usb 3 driver if there is one, and then go to your motherboards website and download the lastest driver
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/122598-usb-3-not-working/#findComment-1631106
Current usb 3 driver?
And i already did install the available drivers on the motherboards website, they didnt do anything.
https://linustechtips.com/topic/122598-usb-3-not-working/#findComment-1631115
Have you try maybe using the one that comes on the CD, if both of those don't work you might have a bad usb 3 controller on your motherboard and you might have to rma
https://linustechtips.com/topic/122598-usb-3-not-working/#findComment-1631122
I dont have the CD.
https://linustechtips.com/topic/122598-usb-3-not-working/#findComment-1631141
wait are u on windows 7?
yes
https://linustechtips.com/topic/122598-usb-3-not-working/#findComment-1631206
Got it working.
https://linustechtips.com/topic/122598-usb-3-not-working/#findComment-1631332
