41 minutes ago, yefiy said:
I set it to 255 no power limited throttle passed p95 84c max CPU temp and vrm 101.1c max so do you think that's all safe 5ghz -3 avx 44cache 1.32v / so is that all safe since I only do gaming or would you rec getting a better CPU cooler nh-d15s
If all you do is gaming, you'll never see those load temperatures. I'd say its fine, and get some airflow over your VRM for extra cushion.
These chips can definitely do just under 1.4v fine with adequate cooling.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1225597-vrm-temps-help/page/2/#findComment-13850198
ok thanks you have been a huge help
https://linustechtips.com/topic/1225597-vrm-temps-help/page/2/#findComment-13850204
