is my power supply enough for rtx 2060 and i7 6700k oc
Solved by Ralf,
10 hours ago, Pc6777 said:Wall of text
is my power supply enough for rtx 2060 and i7 6700k oc, my psu is ehh, its not garbage but not high end I would consider it a mid teir unit but barley mid teir like the low end of mid teir but still not low teir i guess, evga 500 watt 80 plus white it has never caused any problems.
Wattage wise yes, it's enough. Personally I wouldn't use it for that system, let alone overclock with it. But since many people are fine with even worse units, it should work until it doesn't.
If you consider the white EVGA units mid-range, what's low-end for you? The chinese bombs?
