Hello all, before I go crazy I need all the help I can.
Just built a new system, B450m Pro 4, 1660 Super, R3 3300x.
Problem is that I don't get any audio from the pc on the audio jacks, but if I plug the hdmi cable on the graphics card, I get audio on the TV/Monitor I'm using.
Did all the basics including uninstalling the NVIDIA audio drivers, messing with realtek stuff, new drivers from mobo page, all of it.
No clue how to fix it, any help would be immensely appreciated
https://linustechtips.com/topic/1224694-b450m-pro-4-audio-problem/
Hi
Try this it may or may not work
Start
Type --> sound-- This will find --> sound setting <--  Open
Go to top right corner --> Sound control Panel <--  Open
 Connect to output jack -- Headphone or speakers
Go to Playback -- . this is the first option-- . Play with the setting to see witch one work
Ok try this
Go to desktop
Go mouse right click (Drop Menu ) -- go  Display setting
Go to --Sound
Just below -- Master volume , Trouble shoot
Go -- Manage sound Devices
At the Output Devices you should see your Monitor / Tv --Click on it and --Disable
Hope this help
Sorry, didn't work, already done something similar.
When I troubleshoot the only device there (Realtek audio - Speaker) it tells me that the connector is located in the back of the computer, but even when I unplug the cable, the device remains active.
Heard something about NVIDIA drivers and motherboard drivers, but all configs of drivers I try don't work.
Could it be a faulty motherboard? I hope not since there is audio coming out of it.
Also saw somewhere that I would be required to obtain a usb audio card of sorts (maybe a dongle, new to this type of stuff). Could it solve the issue?
EDIT: If required I could provide screenshots of my audio configs to clarify stuff :)
