clear the cmos and then boot
what FCLK did you set it to
what cpu? what specs?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1223695-help-please/#findComment-13835269
Just now, Parsh said:
@gloop here
To clear CMOS (from the ASUS website):
To erase the RTC RAM :
a. Turn off the computer and unplug the power cord.
b. Make two jumper caps short-circuit with a metal conductor. Keep the conductor connected to the jumper caps for about  5-10 seconds,
c. Plug-in the power cord and turn ON the computer.
d. Hold down the <Del> key during the boot process and enter BIOS setup to re-enter data.
2840b332-4add-4840-b9f2-390f10758ec8.jpg fb708978-980b-4f85-a751-e91b85ffd5c7.PNG
* If the above steps do not help, remove the on-board battery and short-circuit the jumpers again to clear the CMOS RTC RAM data.
After clearing the CMOS, reinstall the batttery.
https://linustechtips.com/topic/1223695-help-please/#findComment-13835277
10 hours ago, Parsh said:
should I just unplug my power and it would work ?
unplug everything external like the power plug and the kayboard etc and then clear the cmos
Build Log:
https://linustechtips.com/topic/1223695-help-please/#findComment-13835281
