Corsair has 3 controls/hubs with confusing information for what's need vs what just extra glam. Anyway every tier has its disappointments. Just get the commander pro. At least the only thing you'll be disappointed about is how much you just spent on RGB. Dont worry I sunk 200$ into RGB too.
https://linustechtips.com/topic/1223295-rbg-fan-help/#findComment-13832545
