Hi Guys
Hope everyone is keeping safe
I have an issue with my RTX 2080. I can run heaven benchmark maxed out at 4k on a loop and it runs fine. Temps under control
However, when I run benchmarks i.e. GTA 5 it crashes. When I play games like COD WZ etc it crashes. I have flashed the bios on the card, re-pasted the card, up to date drivers.
WHat can I do?
Thanks
George
https://linustechtips.com/topic/1222823-rtx-2080-problem/
is it overclocked, heaven's kinda outdated for stability? if so dial it back
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1222823-rtx-2080-problem/#findComment-13827858
Just now, GeorgeKellow said:
No overclocks on the card. Heaven works, the rest dont...
heaven working doesn't mean anything, try ddu'ing the drivers. if it still persists, do -400 on the memory, if -400 memory works, then it's a slightly defective card.
https://linustechtips.com/topic/1222823-rtx-2080-problem/#findComment-13827867
  • 1 month later...
Hi so I'm facing this issue with my NVIDIA GeForce RTX 2080 with Max-Q Desing / İ7-8750H CPU @2.20GHz 16 gb ram laptop pc but i get 20 - 50 in Rainbow six siege i tried all settings in Rainbow but didnt help and i dont know what to do my CPU gets 94 *C in other games i still get 144 fps in Rainbow its to low to play idk
https://linustechtips.com/topic/1222823-rtx-2080-problem/#findComment-13936365
