So Im using an prebuild pc from acer, probably one and half years almost. I don't know like I start my pc cpu goes in 5 min to 40-50掳 and if I play no matter what game it goes to 80-90, I rebuild my pc in a new case did help a little but it was not enough. I think it is because my stock cooler馃槀.I heard noctua nh-d15 is a good choice, is it worth?
(P.S I dont want buy an water cooling cause my rusty stock mobo dont include pump header)聽
Thanks for listening!聽
PC:I7 8700,1070 GTX, 2T HDD, M.2 250 GB, ACER NO NAME MAINBOARD聽
https://linustechtips.com/topic/1222523-too-hot/
for some powerful overclocking, yes, but it's pretty expensive.
what country are you buying in?
Primary PC:
i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black聽(with RGB Riing flair) - EVGA G3 650W - dual booting Windows 11 and Fedora Linux聽- Black and green theme, Razer brainwashed me.
PSU tier list
How many watts do I need?
PSU misconceptions, protections explained,聽group reg is bad
https://linustechtips.com/topic/1222523-too-hot/#findComment-13825302
I live in germany聽
https://linustechtips.com/topic/1222523-too-hot/#findComment-13825307
Primary PC:
PSU tier list
https://linustechtips.com/topic/1222523-too-hot/#findComment-13825313
https://linustechtips.com/topic/1222523-too-hot/#findComment-13825328
