My PC was working fine but it suddenly froze while working normally after that i push the restart button then it doesn't boot up.
It spent too much time of BIOS screen.
After that it shows a blank screen with '_' and after sometime it will show a disk read error has occurred.
It will start and boot if I reset the BIOS, but then again after sometime it will froze.
My system specs are old
I3-2100
4GB DDR3 1333mhz ram 2x2
500Gb Seagate HDD (OS  reinstalled windows 8.1) 7Months old
500GB WD almost 10 year old. (It will show same problem even without this HDD)
No dedicated graphics card
Motherboard B75 M gigabyte
Sometimes it boot with single stick of ram (randomly)
Sometimes with both sticks of ram
I tried swapping the slots and ram but to no avail
https://linustechtips.com/topic/1221978-help-needed-a-disk-read-error-has-occurred/
It's either a dying boot drive or some critical data got corrupted preventing it from booting. You could try to repair the windows install, or a complete reinstall. If that doesn't complete you definitely got a dying/dead drive.
I have no signature
Will MBR fix work?
In this case
2 minutes ago, NomNom_ said:
I reinstalled the windows. The HDD is pretty new, it shouldn't be dead this early
if you already did this, then i suppose you have ur answer. No it shouldn't be but it can. Good thing is if you bought it new you can RMA it and get it either repaired or replaced.
I have no signature
So I need to Replace my HDD?
You can't fix it yourself so yeah. Nothing else to do with a dead drive. Luckily 500GB drives cost literally nothing.
The data recovery is costly, and it has around 120GB of photos and Video, 50GB of work files.
Any other solutions because RMA will just give me a new drive here. And will took my old one.
Only thing you can try is connect it to a different PC and see if that can read it. Get what data you can off it. Other then that, nope nothing you can do other then decide how much the data is worth to you and if a data recovery is worth it.
In the mean time maybe start thinking of a backup solution so you can avoid data loss in the future?
I have no signature
Well thank you very much for suggestions,
I will do it right away.
