Hi, IDK if anyone will know the answer to this but here is goes: earlier I was in one of my friends realms and I logged off. I tried re-joining and it got stuck at the loading terrain part. Note that when I try to join any other world it loads up very fast. Also, I tried joing on my phone, my PC and my Xbox. I have connected to an ethernet port and it still has troubble. I logged out when i was in a boat. Could that be a problem and is there any way to fix this? Thanks!
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1221777-minecraft-bedrock-realms-issues/
