So my problems are that every once in a while, it's not that common I would  say like once per game I get a frame drop for like a second, but it is MAJOR, like it drops to like 3 during one sec, the other one is while I'm loading maps it sometimes stops responding for a second, usually comes back, but some times I've had to re launch, I haven't done anything yet, I'm about to verify game files and if that doesn't work I'll re-install my drivers, it's been happening since the last patch, so my guess was that the patch caused instability, but is anybody else getting this? is there a fix that isn't verifying game files or re-installing drivers?
MSI Z87-GD65 - GTX 760 DirectCU II - i5 4670k @4.0GHz - 16GB Corsair Vengeance @1866 MHz
https://linustechtips.com/topic/122124-problems-in-csgo/
csgo is very broken so hard to tell if its your problem
https://linustechtips.com/topic/122124-problems-in-csgo/#findComment-1625614
How so? I hardly ever hear about these kinds of problems.
Verify game files, check CPU and GPU stability (CS is somewhat CPU intensive), and try locking the framerate via console commands(NOT v-sync)..
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/122124-problems-in-csgo/#findComment-1625625
Yea I have it locked at 128
https://linustechtips.com/topic/122124-problems-in-csgo/#findComment-1625632
I think locking it at the tickrate is kind of dumb even though lots of people do it. I lock mine at 120 to match the refresh rate of my monitor. In other words G-Sync without the module.
https://linustechtips.com/topic/122124-problems-in-csgo/#findComment-1625643
They say it used to make a difference back in like 1.6, but valve said that is doesn't really make enough difference to matter, but I don't lose anything by having it locked at the tickrate so I just have it there just because.
https://linustechtips.com/topic/122124-problems-in-csgo/#findComment-1625656
I have csgo problems too mine sticks randomly avery few minutes for a second my other game i play alot is rise of triads and thats ok altho it seems to say im at 100+fps in max video setting and no online multiplayer that i know of. Also i dont know if its server lag or not. Also my wmc does samething watching videos. memtest gives me a few errors and prime 95 shuts down on 2 random cores after a few minutes every time i launch it
https://linustechtips.com/topic/122124-problems-in-csgo/#findComment-1626078
