38 minutes ago, mahyar said:
do you have any background in switching power supply?
if not just take it to an expert
Not even worth it. Average laptop charger is like $40, a tech will tell you the same thing.
Don't mess around inside power supplies unless you know what you're doing. They can and will kill you.
ASU
https://linustechtips.com/topic/1221060-ac-charger/#findComment-13812942
As @mahyar said, unless you know what you're doing, don't. For example there are capacitors inside which can carry dangerous voltage for extended periods of time.
Unless you already own the tools needed to test and replace stuff, it's probably cheaper to buy a new one or get it fixed by someone else. In any case, here's a video that shows you what's involved: Switch Mode Power Supply Repair, SMPS
https://linustechtips.com/topic/1221060-ac-charger/#findComment-13812945
not killing but  really painful i have had shocks like this
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1221060-ac-charger/#findComment-13812951
