Android 10 hotspot problem
Go to solution Solved by Senzelian,
I found this thread on Google's support page.
https://support.google.com/pixelphone/thread/13569854?hl=en
There are some interesting approaches that might help you fix the issue.
I have an interesting problem with hotspot and would need some expert advice...
Here's the deal:
I have Xbox One (Original model if that matters) set up with Android hotspot.
I used to have Nokia 8 with Android 9 and 4G connection and everything was working fine.
No lag or anything for example playing Rocket League (Also worked fine with Honor 6 Lite hotspot which is a trash phone).
This went on for about a year without a single problem.
Then my Nokia died and I just got Oneplus 8 with Android 10.
I set up hotspot and instantly got huge bouncing lag.
Then I tried to join my friends Rocket League game but joining would not work.
We tried Remnant but game said something like "Host is not on a secure connection".
I tried changing Access point bandwitch from 5 to 2,4 but to no avail.
Android 10 also has an option to use "Wi-Fi 6 standard hotspot", tried that but no change.
Restarted Xbox several times, nothing.
Then I remembered reading that if I share my internet to a computer and share that connection to Xbox, it might work.
So I gave it a try and boom, I got to join my friend's game and first got a little lag but then went pretty smoothly. Windows 10 laptop was used in between.
Lag happened also the day before so I don't think it is something that occurs because of my provider but because of the sharing properties.
Sooooo after this long introduction:
Has something changed how the Internet is shared between Android 9 and 10?
Or is it Oneplus's fault?
And more importanty can I do anything about it?
File a ticket and wait for an update of course... :)
Also tried a speedtest, should be sufficient:
Upload: 3,3
Ping: 21ms
Jitter: 1ms
https://linustechtips.com/topic/1220917-android-10-hotspot-problem/
Thanks Senzelian!
After digging through the topic what I found helpful was going here on my Android 10:
Settings -> Wi-fi and network -> SIM-card & network -> Chose my sim-card -> APN  -> chose my current one which said internet -> APN-type -> added DNU with , -> save + reboot. No lag.
