Boot option problem - P8P67
Go to solution Solved by Kilrah,
You must have a USB drive, accessory, card reader or such connected...
Hi, so in the past few weeks I had issues with windows on my P8P67, the problem was that sometimes the windows boot manager will currupt itself, forcing me to reinstall all. After 3 or 4 times I decided to throw windows and switch to pop os. I erased everything in my ssd an installed it. After like 5 days on startup a boot error appeared, "your windows boot/etc.. seems corrupted please insert a media to try the repair", I was really confused by a windows message on a Linux machine. So i started do diagnosis the problem:
1. I erased all partition in the ssd and HDD
2. Checked the boot options with attached only the keyboard (not even the mouse), and here I found something strange, I have 3 boot option, my ssd, HDD, and a generic storage usb, but I had nothing plugged in.
3 I unplugged the ssd and hhd, and it still appears like in the photo
4 I tried resetting the bios, nothing it is still there
So I don't know what it is, can it case the bootloader corrupting? I think maybe?(is a virus?), At this point I only want to discover what it is.
Upgraded to latest bios my P8P67,
CPU 2600K
32 GB Vengeance
Nvidia GTX 970
750 cooler master PSu
240gb ssd
2tb hdd
https://linustechtips.com/topic/1220288-boot-option-problem-p8p67/
F@H
GPD Win 2
Well yes if there's something plugged in them, or if the case includes a card reader connected there
F@H
GPD Win 2
Ok i unplugged the front usb and it has gone thanks didn't thought that a front usb(with nothing plugged) was recognized as a usb device
