She's building a 3d printing and modeling system, she's asking which of the cpu would be an better option intel or Ryzen stability wise as it may need to run 24 - 36 hrs non stop. She does prototyping for projects.
Printer : dremel digilab 3020.
Silent Cerberus - Fractal Design Core500,Ryzen R7 3700x,Scythe Fuma 2,Gigabyte Aorus B550i Pro AX,Crucial Ballistix Elite 3200mhz cl16 16gb,Adata XPG SX8200 nvme 512gb m.2 ssd,Lexar NS100 1tb ssd,Red Dragon RX5700 8gb(bio flashed 5700xt),Corsair SF600 SFX 600w 80+ platinum F-Modular.
Hades - dO.Ob Look into my eyes and see the dark eternal abyss that is your soul and pay for your hidden sins.
Cerberus - the hell hound that guards the gates of hell. Once you enter you'll never escape.
https://linustechtips.com/topic/1220172-question-by-classmate-cpu-for-new-system/
For stability I would say Intel 100%
My 3800x based system has had a couple issues (none that are too big)
  • Cpu stuck at 100mhz after restart
  • Computer freezes up after waking from sleep and then shuts down.
as for my past Intel systems, I’ve never had issues like this. To be clear Ryzen is still great, you just occasionally have some quirks.
I would go with amd because it is stable and it’s cheaper.
I'd go for a 3400G tbh, stable, old enough that it isn't likely to have issues and you don't need to grab a dGPU with it. Cheaper, simpler(so less avenues of failure) and lower power.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
AMD. for the ECC on non xeons
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Price isn't a problem since she spent $1400 on the printer and parts + filliments
Hmm, my 3700X seem to have the same problem, I leave it running overnight and when it wakes it goes to bsod.
Is that cpu even enough to run her cad?
update bios
for cad a 3600x or 3700x with a GPU and 32gb of ram is the way to go as for what GPU that is down to which cad program
Oh, I misunderstood, was thinking she was doing the CAD on another system and this was running the printer. Ignore that!
I'd go last gen tbh whatever she buys, most HW bugs have been dealt with by this point.
K, any good cpu suggestions? Sorry I'm still pretty new at the system needs being a student myself.
a 2700x would be my choice tbh.
1 minute ago, Sorenson said:
This has nothing to do with the issues that I've had. Also ECC is like something you'll never need 99.999999999% of the time IMO.
then go make a thread and we can try to fix it
5 minutes ago, GDRRiley said:
update bios
It happens on updated bios too. Ryzen 3000 cpus are in their infancy architecturally and will have bugs that need to be worked out. Intel is on its like 10th refinement of the same architecture, its why Jayz 2 cents recommends Intel for stability. I love Ryzen, but I can tell you its not as stable as Intel was for me.
K we'll try a put together system in class with the school parts before buying her parts thanks.
Older Ryzen is, my 1700 is rock solid even at 4Ghz with 3400mhz mem
