as cool as possible ?
then set it to the highest RPM you can. but it'll be loud.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1220030-gpu-fan-speed/#findComment-13804269
15 minutes ago, Sensei Vu said:
I want my gpu to be cool as possible what fan speed should I set and on what temperature?
You can't set the temperature, that said - Nvidia GPUs usually run about 25-50mhz faster if under 60C. And another 25mhz faster if under 50C. On air, I found that you can usually get it to run below 60C with fans maxed out. It's loud and obnoxious, so you'll have to decide weather you like 3% better performance or quiet operation at around 70C. I think it's not a hard decision to make.
https://linustechtips.com/topic/1220030-gpu-fan-speed/#findComment-13804342
Just now, Sensei Vu said:
Are you sure?
yes.
Build Log:
https://linustechtips.com/topic/1220030-gpu-fan-speed/#findComment-13804408
