Completely normal if not better than normal temps. GPUs are rated to go into the high 80s - low 90s safely
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1218695-need-little-help/#findComment-13792658
Of course, nothing to worry about if it's below 80C
Desktop benching:
https://linustechtips.com/topic/1218695-need-little-help/#findComment-13792667
its fine.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1218695-need-little-help/#findComment-13792678
