RAM : Hardware Problems were detected??
Go to solution Solved by EXTRADODO,
Seems like the RAM kit itself is faulty. I’m gonna test with different RAMs tomorrow.
Thanks guys.
So, after a few weeks of trials and errors, I finally think of recent BSOD might be hardware problem and start with RAM and boom! “Hardware problems were detected” in Windows Memory Diagnostics Tool. (Image is in Japanese. Sorry...)
It’s still running and I’m hoping someone would tell me what I should do next when this’s finished. Any ideas?
https://linustechtips.com/topic/1218254-ram-hardware-problems-were-detected/
Specs ?
Clear the cmos and then try.
Phone: Pixel 3a (Purple-ish).
Build Log:
The spec is as below ...
CPU : Ryzen 7 3800X (stock, non-overclocked)
GPU : Gigabyte 2080Ti
RAM : Corsair Vengeance Rgb Pro DDR4 3200MHz C16 16GB (8GB x 2)
MOBO : Gigabyte X570 Aorus Pro (BIOS F10 version, I think)
SSD : Corsair MP600 PCIe Gen4 1TB
PSU : Something 850W Gold
AIO : Corsair H115i XT
I'll try cmos and retest it now.
I'll update my event log result on the main post too.
2 minutes ago, ZWELINHTET said:
I’m not sure what that’s it. Can you tell me what should be doing?
It's short for "Direct Over Clock Profile"  that enables target RAM frequency/timings.
I didn't find it in your motherboard manual, but there should be DOCP or D.O.C.P near your CPU settings in BIOS.
Pax vobiscum
I’ve enabled just the XMP2.0 profile. There were no auto over clock options for RAM other than that.
You might want to run memtest86 or the Windows Memory Diagnostics Tool now again, of course. Maybe it helped...
Pax vobiscum
im curious
how did you come up with that conclusion ?
Build Log:
8 hours ago, TofuHaroto said:
im curious
I'm not 100% sure but the result from Windows memory diagnostic tool says that both sticks have bad sectors that causes errors.
I had the same problem with my office PC a while back. I didn't diagnostic anything back then but swapped out the RAMs fixed the problem.
I've used PSU with cables from different brands and got my cables and rgb hub fried.
Maybe, just maybe, that fried my ram too?
Again, I'm not 100% sure.
On 7/6/2020 at 1:22 AM, TofuHaroto said:
im curious
@TofuHaroto Hi there. I would like to update a bit about my current state.
I swapped out the RAM and run a Memory Diagnostic Tool again.
No faulty were detected with the new RAM. *Finally!*
And reset the whole PC (not a clean install with USB stick).
For a while, there were no problems.
So, I downloaded Chrome, Nvidia Geforce Experience, iCue and installed the necessary drivers and settings.
Everything run smooth except when I'm trying to browse Youtube and access violation happened and BOOM!
"Memory Management" with a big BSOD.
I don't know the cause of that BSOD but nothing like that happens till this morning (12hours later since that bsod).
I have a feeling that will happen again. I need to fix this! HELP !!!!!!!!!!!!!!!!!!!!!!
Clear the cmos
Get rid of any sort of over clock.
Build Log:
12 minutes ago, TofuHaroto said:
Clear the cmos
@TofuHaroto Actually, I've cleared the CMOS just after installing new RAMs.
I don't overclock anything but I'm not sure whether the motherboard has auto overclock at stock.
I'm using Gigabyte X570 AORUS PRO.
I have another Intel PC with Z390 Aorus series has something like CPU upgrade bla bla bla profile which was set on default.
Do a clean install.
Don't be lazy ;)
Build Log:
  • 3 months later...
I’m sorry to bring that up again, but I have the exactly same problem, did the clean installation worked for you?
  • 10 months later...
  • 1 year later...
  • 1 month later...
