Is it possible that two monitors are made with same panel (maybe Panda Panel) and they have those different characteristics-
1. One has 1MS response time and other have 4 or 5MS response time (or even 2-3MS response time)
2. Picture quality is not narrowly different.
3. Overall one is good and other one is bad.
https://linustechtips.com/topic/1217461-same-panel-with-difference/
Any given panel will have a maximum performance.
How that panel performance when built into different model displays however is determined by the manufacture of the display and how the 'drive' the panel.
Firmware dictates how it performs up to its maximum potential. This is why u can alter 'overdrive' modes to change the performance of the pixel response times for example. The default color accuracy is also determined by the display manufacturer, the display 'can' be as accurate as the panel can possibly perform but only if the manufacture bothers to calibrate it. Most 'average' consumer monitors (including gaming ones) are not well calibrated out of the box, so they can and will look different even if 2 different Monitor models use the same panel
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
