Hi everyone, I am currently expecting the components of my pc build to arrive however I am not sure if I have everything that I will need to complete my build.
My system will include 4 cooler master MF120 halo fans (RGB) and a cooler master MA620M cpu cooler (also RGB). This means that there will be 5 RGB fans in total that will need to be connected.
The mobo I will be using is the Asus strix x470-i which has:
1 addressable 3-pin header and,
1 RGB 4-pin header.
Ideally I would like to be able to configure all the above through Aura sync.
My question: do I need a splitter? Can I daisy chain the fans on the 3pin and put the CPU cooler fan on the 4pin?
Thanks!
https://linustechtips.com/topic/1216981-rgb-help/
