1 minute ago, iamy7j said:
I have Asus ROG Strix Hero GL503VD i7 7700hq GTX 1050 and it runs hot as 95 degrees on cpu and 80 degrees gpu and it lags as snail when it reaches that point What should i do?
You have 3 options, repaste the laptop, use liquid metal or get a deskop...
High temperatures are farely normal for a laptop, the anemic cooling often isn't enough for the components, but if you want get better temps, open the laptop, remove the cooling ad change the thermal paste, I wouldn't suggest liquid metal on a laptop but if will give you even better temps
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
https://linustechtips.com/topic/1216188-laptop-cooling/#findComment-13771557
Those temps seem about right (compare with this http://forum.notebookreview.com/threads/asus-rog-gl503.805964/)
You can try to repaste your laptop, and if you are lucky, that will help somewhat.
Another option is either undervolt or just limit your CPU speed. This will give some more cooling capacity to the GPU.
What are your ambient temperatures like?
Did you ever clean the fins of the heatsink of your laptop? Maybe a lot of dust has accumulated there and is isolating them somewhat.
https://linustechtips.com/topic/1216188-laptop-cooling/#findComment-13771564
2 minutes ago, iamy7j said:
yes i clean it like in two months i do 3d modelling and programming on this but sometimes it lags so bad that even photoshop lags .
Have you looked at the clockspeeds of the components. Your GPU is probably hitting its termal limit and throttling. It would be good to know, by how much. Same for you CPU.
I would probably go for a repaste first, as it is fairly little work. Sometimes the thermal interface between the CPU/GPU and the cooler can just go bad after some time...
I would advise against going liquid metal, as it can destroy your laptop. Just get some good, non conductive thermal compound.
https://linustechtips.com/topic/1216188-laptop-cooling/#findComment-13771576
what if i undervolt cpu and gpu maybe that will help??
but i dont really know how to undervolt
can you help me with that?
https://linustechtips.com/topic/1216188-laptop-cooling/#findComment-13771582
I have only ever undervolted the GPU in my desktop PC. That worked very well actually, but you should not expect to get a lot out of it, if you are not also lowering clock speeds.
Here is a guide, that I found. I can't testify for it, but it should be a good starting point.
https://genexisx.blogspot.com/2019/09/laptop-undervolting-guide-intelnvidia.html
Just a heads up, I think if you are using intel XTU, some of the settings are already applied while booting, so if your system becomes so unstable, that it is unable to boot, you'll have to reset your CMOS. Throttlestop is apparently only applying it after windows has stared.
But I have done very little research about this, so look it up for yourself. This won't be a quick and easy fix. You'll have to invest some time into this!
https://linustechtips.com/topic/1216188-laptop-cooling/#findComment-13771757
