HELP my trusty asus x470 gaming f is not posting after 2 weak of non useage  aka sit and collect dust here what I have try so far
1 clear cmos
2 disamble every thing and put it on the mobo box as a safe static clean work enviroment as linus say
3 wear livestrong braselet ok jokeing i touch the ground powersupply regulary
4 clean the mobo clean of dust with dam cloth
5 sit to dry
6 place it on the mobo box and plugin the switch for the power button
7 plugin a cpu
hear is what i get no qled were lit up but standby poweris and when i plugin the lan the orange ligth come on and blink according to the manunal this is normal
and i have change the cmos battry as well
https://linustechtips.com/topic/1216173-mobo-not-power-on/
Specs ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1216173-mobo-not-power-on/#findComment-13771460
