System crash while attempting overclocking
By
mr.squishy
in Troubleshooting
in Troubleshooting
Solved by Polyvalent,
See that box in the first picture that says "CPU voltage"? Bump that up a few notches until you get a stable overclock. Make sure you look up the maximum voltage for your CPU, which in this case I believe is 1.5 volts. You don't really want to get any father than 1.45 or else you might risk damage to your cpu or motherboard.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases4 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
