im using an asrock b450m pro4 and im trying to oc my memory to 3200mhz as its specified but i cant.
CPU: AMD Ryzen 5 3600, GPU: Asus ROG Strix GTX 1070, RAM: T force rgb 16gb 3200Mhz, Mobo: Asrock B450M Pro4, Storage: Adata 128Gb SSD and Seagate Barracuda 1Tb HDD 7.2kRPM, PSU: Corsair 750W 80+ bronze,Case: Corsair 280x, Headphones: Sennheiser Momentum 2.0 Wireless, Speakers: Bose Companion Speakers
https://linustechtips.com/topic/1216009-help-with-memory-oc/
ive done the basic bios arrangements
https://linustechtips.com/topic/1216009-help-with-memory-oc/#findComment-13770202
Define Basic Bios arrangements? Did you manually set all timings and speeds etc or just do xmp profile?
CPU: Intel i7 9700K | Motherboard: MSI MPG Z390 Gaming Plus | RAM: 8GB x 2 G.SKILL Ripjaws 3600MHz | GPU: MSI GeForce RTX 2070 SUPER GAMING X | PSU: EVGA SuperNOVA 850 G2 80+ GOLD | Cooling: NOCTUA NH-D15 Chromax Black
https://linustechtips.com/topic/1216009-help-with-memory-oc/#findComment-13770209
xmp
https://linustechtips.com/topic/1216009-help-with-memory-oc/#findComment-13770210
Are you using the Asrock motherboard utility that could possibly be overwriting your bios xmp settings back to default? If not I would try doing it manually rather than XMP.
https://linustechtips.com/topic/1216009-help-with-memory-oc/#findComment-13770229
it was a hardware issue, apparently in the mobo manual if you want to oc it must be in a2/b2
https://linustechtips.com/topic/1216009-help-with-memory-oc/#findComment-13770250
Yes, that is correct.
AsRock also specifies the slots and the "recommended" DRAM frequency, based whether a Zen / Zen+ / Zen 2 CPUs is used.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1216009-help-with-memory-oc/#findComment-13770290
