Need help for air flow
Go to solution Solved by ayazam,
your cpu get fresh air from the front intake fan, its a good setup :)
i suppose it looks like this?
airflow: blue - intake, red - exhaust
I‘d put one in the back as an exhaust if that’s possible in your case
also replace your intel stock cooler even a cheap 20$ tower cooler would be better
Hi
hi
https://linustechtips.com/topic/1215876-need-help-for-air-flow/#findComment-13769332
CPU Ryzen 7 5700X @-30 || Motherboard MSI B550-A PRO MAX || RAM Team T-Create Exp 3600Mhz C18 || GPU Gainward RTX 3060 Ti Ghost || Case Fractal MiDi R2 || Storage 980 1TB - CS2241 1TB - WD10EARS - 3x ST2000DM008 - WD30EZRX - ST4000NM003 - 3x ST4000DM004 || PSU Corsair RM550 || Display(s) Philips 242M8 - LG 22MP65HQ || Cooling Thermalright Peerless Assassin 120 SE || Keyboard Topre Type Heaven - Akko 3068 - Vortex GT9 || Mouse Logitech G403 Prodigy || Sound Moondrop Chu 2 || Operating System Windows 10 Pro 22H2
https://linustechtips.com/topic/1215876-need-help-for-air-flow/#findComment-13769368
